when i was rolling with my car after a while the brake pedal was starting to brake at lower and lower position till the car dosent brake... so i decided to change the master cylinder.
now im trying to bleed the brake system i bleeded the master cylinder, then when im bleeding the lines, i broke a bleeder. i heard that i can still bleed the line by loosing the hose going to caliper, i did so the 2 1st time oil was "squirting" then now, theres only 3-4drops,like if the cylinder wasnt building any pressure. i checked the lines and i have no leaks.
any hints? cant be the brake booster?
note:the car is a.b.s.
