Braided stainless hose flaws
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
I bought some -10 Mr. Gasket braided hose, and it has quite a few of these annoying cosmetic flaws in the braid. Is there another brand that doesn't have this problem? Aeroquip? Russell? My local shop doesn't stock any of these so I can't see them before buying. Thanks
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
no your right that looks like crap, im not really sure what brand i got but i don't think it was mr gasket i bought all my stiff from either summit or murrys and didn't have any issues like that.
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
thats being a tid bit anal... but i've seen a lot of russell hoseing come through my work and its always looked nice...
have you looked at the black nylon braided stuff?
supraguru05
Dec 16, 2005
737
louisville ky
earls prolite 350
or the perform o flex stainless line
ive used both with great sucess
and also if your that worried about the hose you better be real careful when assembling the hose ends because not scratching them is a pain
Rennat
5psi...? haha
Dec 6, 2005
2,844
Tracy, CA
supraguru05;1285585 said:
earls prolite 350
an fittings are a little hard to assemble... i like using the pushlock fittings...
Dec 3, 2003
6,653
Canada
tekdeus;1285718 said:
I've never bought braided hose before, and this stuff looks like it has defects. My car is full of flaws, I'd just like to avoid adding more if don't have to ;)
lol You are now learning, nothing is perfect! :biglaugh:
shaeff
Kurt is FTMFW x2!!!!
10
Around
earls prolite 350
Get some -AN wrenches, and the vice inserts. No more scratches! ;)
Nah, once you've got it figured out, it's pretty easy. It still sucks when you get a fray into your finger, but I had very little issues putting together my lines.
Dec 3, 2003
6,653
Canada
The wrenches are only good for the portion that screws on. The actual part that you need to tighten to put the braid line together requires a different wrench, not an A&N. ;)
shaeff
10
Around
[thumb]http://i133.photobucket.com/albums/q56/upgradedsupra/AN.jpg[/thumb]
I can't see the pic while at work. (blocked. :() When I'm assembling the hose end to the hose, I use the vice insert, and twist the hose into the end, rather than try to twist the end onto the hose.
Or am I reading you wrong?
supraguru05
Dec 16, 2005
737
louisville ky
100% correct. i have AN wrenches and the vise inserts but i still have to use tape to reduce scratches. the ends require large standard wrenches (dont use adjustable wrenches). all and all im not worried about little scratches on them.
shaeff
10
Around
Oh, I gotcha. LOL. Yeah, i just line my wrenches with a super thin rag, like an old worn out T-shirt. That seems to do the trick.
