BOV Spraying Oil
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Okay, HUGE PCV lines and valve cover fittings installed.
problem presists (but only at 20psi, non-existant at 15psi). I admit, I have yet to flush out the IC with gasoline. That's tonight and tomorrow's goal.
if this doesnt do it.. I have a little less than a month before my turbo's warranty runs out..
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Jeez! I hope this does it.. but to be honest I'm starting to have my suspicions about this turbo. I getting prepared to have my supra down for another two months.. depending on how SP treats me this time.
And thats even if the problem gets fixed! I talked to one poor fella who sent it back and it still had blown seals! :(
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
Update: finished up with the IC flush.. I took it out for a spin and the BOV only sprayed a tiny ammount of oil mixed with gas.. just a few drops. I think this finally did the trick! I'm gonna keep boostin' hard and see if it starts to blow out oil again indicating blown turbo seals.
Thanks again IJ!
Good luck Hott........I just finished cleaning MKIIIVixen's (Vonda) intercooler and pipes. We have her newly upgraded ct26 ready to put back on. I will be busy all day tomorrow getting hers running again and then trying to install my avc-r. I'd rather install two turbos than work on that ebc, but you got to do what you got to do.
The guy that rebuilt her turbo, seems to think that her problem was in the turbo itself and not the rings. I know you are hardly ever wrong IJ, but for the love of God, I hope your wrong this time. Either way, I've got her new catch can on it's way here. I will get it on whenever it arrives. Maybe between the new turbo and the catch can it will fix her oil leak problem.
Sorry to post my problems on your thread Hott, but you know how dang rude and crude I am. Sometimes I can't help it. The bad just oozes out of me..........;)
Free bump for Hott..............I got her turbo installed and everything cleaned up. Now I need to figure out where to hook the catch can to. I think I know where, but I'm going to see if I can get some pictures of someone elses setup...........lol
Glad to see yours is running good Hott........That IJ is one fart smeller..............;)
