bov issue
aznboik1mva
328
Manchester,Ct
heres the story, i traded a front bumper for blitz blow off valve welded on a pipe. the thing is the pipe is 1.5 inches in diamer and i cant find a solution 2 put it on my 7m. any ideas?
nsngarage
210
Pittsburgh, PA
You don't have any rubber couplers that are different sizes on each end? like a rubber adapter? I've seen them all over autozone/advance, places like that.. let us know whats up
Supracentral
10
Have it cut off the undersized pipe and welded to an appropriately sized pipe.
Adding a massive restriction to your intake path is a downgrade in performance.
koldfire08
139
Las Vegas
That will more then definately restrict airflow, which in return make you loose performance.
Stock piping is already 2.5" and Your going to restrict it down to 1.5"
I'd say, Re-Weld the BOV onto another 2.5" Pipe.
Failure14
276
Ohio
Yea if you can get the blow off valve off the pipe and get a 2.5" pipe then you can just
take it too a local weilder and they can do it no problem....
Or if you cant get it off the current pipe im sure a weilder can also do that also.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
You can also buy a section of the appropriate size pipe with the blitz flange already welded on to it. They're all over ebay...
