super.secret.supra.club;1653907 said:is there smoke puffing out if you remove the oil cap and let it idle
was it so hard to answer this question?
super.secret.supra.club;1654639 said:was it so hard to answer this question?
JStoked;1654662 said:Sry I missunderstood you. Do you mean out of the exhaust or out of the oil cap?
Devin LeBlanc;1654620 said:Just throw a compression gauge on it, but you have to remove all 6 spark plugs when you do it and make sure your battery is strong when you do the test..
JStoked;1654795 said:Yes there is smoke coming out when it idles
Yes sir you are wright. I just wanted to know because I was going to sell them. I will just let the buyer know what's up.Supracentral;1654828 said:No easy way to tell other than excessive play. I suspect you've got an engine problem, not a turbo problem. However degraded oil will effect turbo bearings and all of that pressure and poor return can effect the seals. You'll have to address the engine problems 1st.
Man you will know. Mine looked like an old train. You will know that somthing is wrong.7M-KDL;1654833 said:so how much "smoke" coming out of the cap is bad? correct me if im wrong but i would think you will always have oil mist coming out due to it being slung around in the cam covers wouldn't you. i mean that is the same oil mist the pcv picks up and sends through the intake but with the cap off some comes out there too/instead. is "mist" and "smoke" a different thing or is it all because of smell?
any chance of posting a open oil cap video with good vs bad?
Supracentral;1655096 said:Visible smoke, unless in insane amounts (like described by the OP) isn't really a good diagnostic tool.
