Bored As All Hell Tell Me What You Think It Will Run Down The 1/4Mile
Turbo Habanero
4,229
Tucson,AZ
IndigoMKII;1860838 said:
I'll guess 13.8 @ 105 due to the tires, mine isn't nearly as modded and I can turn over the hankook ventus rs3's at will.
Yea i here people say they can roast the tires from seconds gear rolls at like 40mph but i'm pretty sure unless i clutch droped mine i would have good traction
In first they will spin and shifting into second they spin for a second or two and chirp going into third (This is on the Street)
IndigoMKII
2,181
Madison, Virginia
With it being on a prepped track, will a street tire really hook THAT much better? So instead of roasting first and some of second you'll just roast first and chirp second. Depending on how far out they prep the track you might still have second gear problems.
If you do one HELL of a driver mod 13.2 @ 107 would be my guess, but now switch out those tires with some slicks and get them nice and sticky..:naughty:
Turbo Habanero
4,229
Tucson,AZ
This might help with the guessing a little here are some video's of my last time at the track
My mods then were
CT26 60-1 on 11psi dropping to 8-9psi
Autozone intake with crappy adapter
560cc with lex afm
TPS Issues
225/40/r18x7.5
stock fuel pump
uego running 11.6 afr dropping to 11.2
3inch exhaust NO cat with a Stock Turbo Elbow
All video's are of the same run i ran a 14.3 @ 98mph also had a 130lb passenger
The supra i was racing was a 1jz on 18psi 60-1 T4 turbo 14.7 @ 108 after red lighting
I am not the camera car
[video=youtube;bHHaF2gX1Ok]http://www.youtube.com/watch?v=bHHaF2gX1Ok[/video]
You can see the times in this video
[video=youtube;81C6fJ19c-I]http://www.youtube.com/watch?v=81C6fJ19c-I[/video]
another POV down the track
[video=youtube;HEwOiuhPzHE]http://www.youtube.com/watch?v=HEwOiuhPzHE[/video]
Turbo Habanero
4,229
Tucson,AZ
kysus;1860880 said:
always run with out bumpa
Lol yeah that days i was up all night getting the car ready and when time came around i didn't have time to put it back on. figured it was not going to be a huge deal
radiod
1,342
Abbotsford, BC
Shhhhhh, you did it to save weight..... ;)
gsxr141
1,158
10
rochester
i would hope it does high 12's. my 90 with just an air filter, bic ddp, and full 3in exhaust went 14.1 at 99. this included fuel cut in 2nd, 3rd, and 4th gear. fml. also, i was on 17x10.5 cobra wheels, 315-35-17 nitto 555's and running 10 lbs of boost.
i'm hoping for 12's once i install the 560's, lex afm, and afc.
te72
Classifieds Moderator
6,611
7
WHYoming
Err... I'm going to guess they had a hell of a time hooking up, because that is about 1.5 seconds slow for that trap speed...
destrux
1,183
10
PA
The day/night temp problem is most likely just a thermostat. Assuming it's not overheating at all. It sounds like the thermostat isn't closing all the way.
