what should I be ok on?? I have the mhg, Not sure about the head bolts,I also have intake, hardpipes, and 3in exhaust.
FatalStylez;1230285 said:What about me?
Wills7MGTE;1230206 said:I have had a 90 dollar HKS MBC since 2004, I have 3 inch downpipe, 3 inch high flow cat, 3 inc blitz nur spec catback, spearco replica FMIC, hardpipes, HKS SSQV, K&N FIPK w/ LIPP accordian replacement (aluminum baby) and various other things. Run 10psi all the time on my auto 7MGTE, ran 12 once, hit fuel cut u can run 11 in my car, its a 90 auto but i keep it at 10 since its safer and u dont risk spiking to Fuel cut.
You'll be fine bro
MKIII TURBO60-1;1230356 said:are u still running stock boost gauge if so go get an aftermarket one so u actually know what ur running, i also suggest getting arp head bolts or studs, do them one at a time so u dont have to change the headgasket, and double check ur spark plugs make sure ur getting a good burn
MKIII TURBO60-1;1230365 said:i would also check my afr's while running 10psi, on a dyno or with a wideband, if they are good u are good to go, other wise u could run lean and do more than pop a headgasket
FatalStylez;1229860 said:what should I be ok on?? I have the mhg, Not sure about the head bolts,I also have intake, hardpipes, and 3in exhaust.
