starscream5000 said:A little food for thought: If you go with a better, larger turbo than a CT-26, then the amount of boost you can have without blowing it up will most likely be lower than the CT-26. Boost doesn't mean shit dude, it's how much air the turbo flows at any given boost that counts. You could run your CT to 13 psi before fuel cut (theoretically). Now put on a larger turbo that's better flowing and you may only be able to push 9 psi before fuel cut, make sense?
hollisterguy40 said:what would be the best way to bypass fuel cut?
http://www.supramania.com/forums/showthread.php?t=32114theKnifeArtist said:hollister guy from miami, huh? what year is your car again?
hollisterguy40 said:http://www.supramania.com/forums/showthread.php?t=32114
this is the car im buying and i already have the money i need to fix it
as you knoe im kinda lost this is my first project car my plans for it were to use a 2.0mm metal head gasket and buy a good radiator to get the car running so im left with a little money and i was thinking of upgrading my ct 26 to gain some hp......any advise would be appreciated and im sorry ill use the search from now on
