Boost problems!
ojonesjr
Boost Hungry!!!!!
Aug 30, 2005
PA
Guys,
Need some help...
Ok, I was driving down Route 80 in PA at about 110 boosting to about 13 psi I hit the gas for extra boost I heard the final Pssssss of the bov, engine light came I backed off the gas then the engine light went off. After that, I cannot boost beyond 5psi...No more engine light. Sup idles fine. I have pretty much replaced all intercooler pipes with hardpipes with the exception of the one connected directly to the turbo...It is secure and no leak...could it be that one of the bov's are bad? How can I check to see if either the HKS or bosch is out? HKS is about 6 yrs old...
Here is my current setup...
K&N FIPK
3" exhaust all the way back
HKS electronic boost controller profec b II
HKS SSQV bov
Bosch bov
SAFC II Tuned
Lexus AFM
550cc injectors
Wide band O2
AFPR
walbro fuel pump
CT26 with 57 trim
intercooler Hard pipes 2.25
Thoughts?
Thanks!
Pokey2301
204
Spangdahlem, Germany
why do you have 2 bovs on your car? and are you hitting fuel cut? and is your eng temp staying normal? any smoke coming out of the exhaust? and check the turbo for shaft play
You were at 13psi and werent wot?
Why the 2 bov?
Have you checked for codes?
Have you checked for boost leaks?
ojonesjr
Boost Hungry!!!!!
Aug 30, 2005
PA
Why do I have 2 bov's...? I was running the HKS with stock bov closed off...caused car to stall out could regulate...I put the bosch bov in that corrected the problem...No, I am not hitting fuel cut...all good there. Engine temp staying normal...checked for leaks. Last year I replaced all intercooler hoses with hardpipes with the exception of the hose from the turbo. All looks good...Check engine light is not on anymore.
Pokey2301
204
Why the 2 bov?
i see now, i thought he blew at 13psi, not boosting more...
that is weird
---------- Post added at 06:37 PM ---------- Previous post was at 06:36 PM ----------
check your wastegate, and most likely the pipe coming off your turbo is your culprit, cracks almost all the time by the clamp
jonahs_supra
1,015
Lancaster, Ohio, United States
checked wastegate hose?
check for codes anyways...hard faults will only turn on light
hows it run on 5psi WOT?
how was your boost regulated? shimmed wastegate? mbc?ebc?
stock turbo?
---------- Post added at 09:47 PM ---------- Previous post was at 09:42 PM ----------
ojonesjr;1732802 said:
No, I did not...Not really sure how to do that...
besides your underhood fuse box there is a black box about 1"x1"
remove the lid
place a paper clip or wire to te1 and e1 like the link i posted
http://www.troublecodes.net/Toyota/
next watch this video and count the codes
http://www.youtube.com/watch?v=XVoJihqqbYs
ojonesjr
Boost Hungry!!!!!
Aug 30, 2005
PA
Will check codes in the a.m.
Car runs ok until I get around 8 psi...then sputter, sputter
I am using ebc HKS...
jonahs_supra
1,015
Pokey2301;1732833 said:
if he blew a hose, you wouldnt be able to build boost
depends on how big the hose is
i found i had a vaccum line popped off yesterday and it didnt make a HUGE difference on performance
if it was the intercooler piping it wouldnt build boost at all
a ripped or dry rotted coupler possibly
