boost prob , cant get any more than 10psi !!!!
turbonutter
somerset , uk
well iv found a leak !!!
iv sorted that now but its getting to 10 - 11 psi and the wg opens as i can hear the screemer pipe , whats that about ???
IHI-RHC7
"The Boss"
Oregon
Divorced wastegate, don't you love it?
Check to see if there's an adjustment on the very top of your wastegate, if there is, crank it down a few turns and that should delay the opening of the gate a few psi.
turbonutter
somerset , uk
supramike7m said:
hey bro, glad you found that leak. where was it? was it near the manifold, turbo to ic pipe?
it was between the ic and the manifold , it was a blanking plug that wasnt sealing right !!
iv gota cut the top ic pipe and find a samco hose to replace the bit where the blanking plug is but it ok for now !
i think my boost controller vacum lines are on wrong as well , if i turn the boost up on the ebc the boost goes down !!!
bout to go and have another play about now
