Wait a second unless I totally miss my understanding here there is no point at which the engine will have all the valves sealed up and allow the intake mani to be pressurized. And a valve leak isn't the same as a boost leak either I don't think. I don't think you can boost leak test your intake mani in the test while it is still bolted to the head. It's not possible I don't think.
Would the motor even run if there was a point at which the valves were all sealed completely? And if so then we would be turning the motor to ?? degrees to or from TDC to place the valves here for the boost leak test. Wouldn't this also cause possible valvestem seal issues too?
I may be wrong but this is my understanding of a boost leak test.
isolate the entire IC system from the turbo outlet to the TB and see if pressure is held. check for leaks, correct any, test again.
Intake mani can be tested off engine if all runners are plugged and pcv valve port is sealed up too.
Right?
---------- Post added at 01:09 AM ---------- Previous post was at 01:07 AM ----------
Oh, and I run the test at a little above the peak boost the system will ever see to be sure it will hold the lower PSI without issues. And ya, I use the spray bottle with soapy water to look for smaller leaks shown by bubble generation.
