on the driver side there is a boost pressure sensor on the tire well with a hose coming up to it. follow the hose and you will see it leads to other hoses and finally to the intake manifold. any of those hoses are fine to use. i used the one that went across the engine to the heater vsv. thinking about it now i should sleeve it with something to protect it from the heat.
