boost hook up
mista_sup
211
atlanta
hello need help hooking up this boost guage correctly. it a carbon fiber auto meater. 89 na that was switched to turbo. help...
mista_sup;1046970 said:
where is the best, most accurate place to tap into for the boost gauge?
sogi99
115
Elk Grove, CA
if you have a turbo manifold there's a small nipple at the back of the intake by the brake booster. if you don't you have to make one.
j3pz
still learning
on the driver side there is a boost pressure sensor on the tire well with a hose coming up to it. follow the hose and you will see it leads to other hoses and finally to the intake manifold. any of those hoses are fine to use. i used the one that went across the engine to the heater vsv. thinking about it now i should sleeve it with something to protect it from the heat.
