Boost Gauge
twoaudio
More Power
Jun 10, 2006
VA
I put my engine back together but i can't figure out were the vacuum hose for the boost gauge go. Can someone help me
Pictures would help alot... I didn't not take engine apart someone else did thats wh I am lost.
noredline
Yeah, I'd stands on that.
Sep 26, 2006
94
Chandler, AZ
From what I understand you need like a small T adapter that you can get at AutoZone to tap into any vacuum line, so at that point it is routing to the boost gauge.
twoaudio
More Power
Jun 10, 2006
VA
after looking a the picture my stock gauge must be bad. All I am getting is -4 on the thing. I can tell that it is boosting.
thanks
clifftrail
128
Abq
Your stock one is electric and gets its signal from the boost sensor under the hood. Are you sure its hooked up? There is no vacuum running through the firewall for that, the pressure sensor is near the drivers side shock tower just in front of where the cruise control is. Make sure its got the vacuum source hooked up and the electrical connector plugged into it. GL.
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
Yea, to the left of my hand (couple posts up) you can see the boost sensor.. It's black with a silver sticker on it.. There is a vacuum line connected right under it. If it is connected there, then trace it back to the back/top of the firewall and make sure all those lines are connected..
twoaudio
More Power
Jun 10, 2006
VA
It is hooked up. when I unhook it is the gauge goes up to 8psi. When it is hooked up it's on -4
