I am curious to know where you hook the boost gage up to (which vac. port specifically)
I had it on the right side of the two prongs on top of the TB. but I would not read and vac. pressure Only after I gave it a little gas (open the TB.). But I would read bost… so I then hooked it up to the AC vac. line. And would read 20 PSI Vac (idel) but I would not read any boost….
and where do you hook your 2nd (second) BOV vac. line up to… would it be alright to tap into the same vac line as the stock BOV…
I did search but all i got was
"do i need to get new IC piping if i get a new BOV. or do i need to get all new stuff"
-Thanks
-Thanks
