Boost Creep?
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
so this is the situation.
i'm currently running stock boost. no manual boost controller.
the wastegate opens at 5psi and it'll climb to 10psi.
i got a ddp.
i thought the wg was supposed to stay closed until set pressure, no?
what goes on here?
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
I have this same problem yet I don't even have a DDP. Actuator set to 7psi holds 7psi till 4000rpm then just shoots up to 13psi by redline with no boost controller. Mods are home made 3" exhaust from elbow back, modified stock elbow and a K&N drop in filter.
jtran8
199
wichita kansas
EBC only iliminate boost spike , it won't help your boost creep . 9psi -12psi of boost is normal for 3" turbo back+cold air intake.Threre onlytwo reasonsthat you have boost creep #1 if the hose between turbo and wastegate accuator wore out and leaks #2 if your set up so efficient that cause more air than waste can open . So if the your waste gate accuator hose still in good condition , than you have to port your wastegate to iliminate boost creep if you want to run under 10psi of boost.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
well, i wanted to run it at like 12-13psi, but i have yet to put the boost controller in because i don't want it to creep up after i set it higher. am i thinking clearly? or if i set it higher, would it stay at the correct level?
and my vacuum line is good, its a nice flexible hosetechniques line
jtran8
199
wichita kansas
as your fist post, you said boost creep to 10psi , is that on 3rd gear at 6000 rpm ? if so then you are in good shape and yes you can install boost controller and turn up the boost to 13psi , if your head gasket is fixed or at list retorques it. I thought you only want to run under 10psi .
Syris said:
you can get an ebc to eliminate it
Ummm nope if it's got creep it's a mechanical issue and no EBC will correct it....
Creep is usually not enough flow from the WG Valve to control/reduce Turbine speed at high rpm due to the volume of gas flow the engine produces.
In the CT the WG Hole is very restrictive along with the stock elbow but in this case he has a DDP.
If you have any shims remove them as preloading the actuator reduces it's travel when opening. (there might be just enough travel in a stock actuator to control it unshimmed)
Add an EBC to control the actuator will improve low end response as it holds the WG shut until your boost setting, plumbed stock the WG begins to open as soon as boost goes + and this slows spool.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
i don't have any shims, and i can't tell you exactly at what gear and what rpm what my boost sits at because it's automatic and hard to tell what gear im in when boosting..this erratic auto doesn't really help.
according to my headgasket setup...oem hg+arp's@85ft.lbs, i should be safe up to fuel cut.
daddycat31
45
Milwaukee, Wisconsin
how many washer are supposed to be on the waste gate? mine wasshimmed when i bought it. i am having a similar issue, but i have a mbc. for the most part it stays right 10psi, but sometimes when i punch it, it will shoot upo to like 16psi and i hit fuel cut.
