Boost controlers..>?
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
Greddy Profec B Spec 2
Works nicely.
Can set boost pressure/responce/consistency
has built in boost gauge/warning functions/limiters
High/low boost settings
You should also check out the apexi avc-r
Personally, I would stay away from manual boost controllers...too much creep and limited adjustments/tweeking
Wills7MGTE
( . )( . )'s RULE!!!!
May 12, 2006
1,077
Jackson, MO
call me simple but I run an HKS Manual Boost controller I got back in 03, it may be crude, cheap and require a bit of tuning a couple times a year but I like it and I will stay with it until I start running crazy boost levels then I may look at something else.
Can't beat it for less than 80 bucks new
Wills7MGTE
May 12, 2006
1,077
Jackson, MO
Just a note, I haven't had boost creep, if the weather changes in significant temperature, say 20 to 30 degrees you'll need to turn the boost down slightly, usually not hard, make a few pulls at WOT and adjust in small amounts, I got it to 3 to 4 pulls max and I stay at 10psi which is where I want it.
never had boost creep, never had limited adjustability, and the solenoids in some boost controllers can go bad (profec b my buddy has did it) and thats a pain.
