Alright, I just purchased a mechanical boost gauge and an electric oil pressure gauge for my car. After searching around I think I have found the correct locations to attach the vac line and the sending unit but just wanted to start a thread to help all the newbs (like myself) that spend a bunch of time trying to figure it out.
First - Boost
It appears the best place to get boost is to T into the vac line to the stock boost sending unit. There seems to be a few different ways to run the line to the gauge, what have people found to be the most direct and clean way to route it? I would prefer to not run it all the way across to the passenger side and then back to the driver side, but I don't want to drill through the fire wall either (two methods i have found on this site). Car is a 5 spd so I cannot go through where the clutch master is as some have with autos.
Opinions?
Second - Oil Pressure
Looks like people put the sending unit off the stock sending unit location or use an adaptor plate off the oil filter. Which location is "better" and why? I would like a good reason why one is better than the other before i decide where to go.
Discuss, and thanks for the help
Dave
First - Boost
Opinions?
Dave
