Has anybody used the kenne bell boost a pump on their 7m or 1jz? I am gonna use it on my mustang but was thinking about getting one for my new 1jz build. Let me know if anybody has used it and if so how did it work out
kenne bell boost a pump info said:Kenne Bell, The Innovators, have done it again: An ingenious, reliable yet simple solution to your fuel system needs. Just tap into your existing fuel pump wiring. Imagine 50% more fuel delivery and horsepower without the hassle and expense of draining and removing the gas tank, tapping into fuel lines or adding a noisy in-line pump - and it doesn't heat the fuel up. The Kenne Bell BOOST-A-PUMP is fully adjustable from 1% to 50% with the mere turn of a dial, so pump output can be varied to match your engine's needs. No longer are you "locked in" to a fixed pump capacity and/or pressure. It activates ONLY at full throttle (naturally aspirated) or at 3 psi (turbo or supercharged). And it acts as a voltage regulator by compensating for any and all system voltage fluctuations.
klaasjoe;933760 said:Has anybody used the kenne bell boost a pump on their 7m or 1jz? I am gonna use it on my mustang but was thinking about getting one for my new 1jz build. Let me know if anybody has used it and if so how did it work out
Down but not out;934068 said:Fitting a Walbro pump isn't hard and they aren't that loud unless you have a stripped interior like mine..
CPT Furious;934916 said:Mike,
Did you ever find out from your dealer what the Walbros were rated for voltage wise? Someone else might have been looking into it, but I thought it might have been you...
Supracentral;934992 said:Overvolting an electric motor is NOT a good idea.
