Well, boost leak, no, but it will leak exhaust out the dump tube constantly which gets annoying...
redmaro;1279864 said:Its mosly likely modifed by some shop with a Turbonectics housing and center section.
BTW it looks pretty nice.
jonny87turbo;1280092 said:If you go with randys down pipe let us know how it goes. Most the guys that had the problem with these turbos ran the cooleeze down pipe with no problems that I heard of.
MarkIII4Me;1279254 said:No adapter required. It bolts right up to the stock exhaust manifold. However, a spacer is required to keep the inducer housing from resting against it. Supposedly, even the stock turbo elbow bolts up. I'm hoping this is true since I have a sweet, one piece, completely mandrel bent (even last 15 degree bend), ceramic coated BIC DDP I'm planning on using.
