Just wondering about the performance differences between a bolt-on turbo like the Boss/Comp 61mm turbos and a full T4 setup with a GT35R? I know a T4 manifold and external wastegate will have better flow and boost control, and probably have a better powerband, but how much of a difference is it really?
The ball-bearing Boss SS turbo with larger exhaust and compressor is extremely close in specs with a GT35R. It has a larger than stock wastegate, so the only real downsides I can see might be the turbulence of exhaust through the stock manifold and a CT26-style 3" downpipe. And I would plan to recirulate the wastgate flow which would just cause turbulence at the bottom of the downpipe, instead of at the top elbow. Not sure if that would make any difference.
