Hey guys, I've been lurking here for awhile and can't find a direct answer to a situation i'm encountering. When I shut off the car, I can hear coolant boiling in the upper radiator hose, and the hose itself never feels firm. And yesterday morning I found a coolant spot on the driveway, coming from somewhere around the water hose below the CPS.
The thing that has me nervous about this is the stock temp gauge stays rock solid just below halfway, and my greddy gauge will read between 85*-105*C and never move any higher. The greddy temp sensor is mounted where the bvsv used to be, if it matters. My heater vsv gave up the ghost, so to test for air in the coolant I have the vacuum valve held open, and I have constant heat with no air pockets. I've burped the system repeatedly, and I replaced the stock mech fan & clutch with a dual flex-a-lite setup--initially, I had it wired up to come on with the ignition, but changed it to come on when the a/c fans would have come on (which usually makes the fans kick on at about 103*-105*C) and the resulting coolant temps are nearly identical to the always-on fan setup so far. Last night in about 12*C (55*F) temps the fan came on once at a stoplight, and once again when I parked it before the turbotimer time elapsed. Both times the fans stayed on for about 10 seconds until temps came back down below 100*C. Everything feels great, seems to be staying cool, but I usually feel that with this car, when nothing's wrong, something's wrong.
Everything seems fine, the car drives great, but something's obviously wrong. Anyone have any ideas?
I'm mainly worried that I'm doing damage that is not yet apparent. I'm going to go get a replacement for that potentially leaky hose, but after that...I'm out of ideas--I'll have all new hoses at that point, and I'm not sure what else to check.
I just finished a hg job on my engine, my first one ever, 2nd one on the car since I've owned it, so I'm really nervous about everything going ok.
Here's what was done in the hg job:
Toyota hg on resurfaced head
ARP bolts tightened to 90ft/lbs
egr blocked off
isc/tb water hoses eliminated
new Toyota radiator hoses
new Toyota turbo water hoses
new Toyota heater hoses
new Toyota t-stat & rad cap
Toyota water pump, oem-style radiator 25k old
new Champion platinum plugs
Any help would be greatly appreciated!
egr blocked off
