Hey all,
So I've been lurking for nearly 2 years now and have found the forum to be extremely helpful with everything I've needed so far. I've got two bodywork related questions that I haven't found discussed in any threads.
For reference, here is a picture of my '89 Targa.
Questions:
1) The front fender mud guards (apparently that's what they're called per the A70 Chassis Collision Repair manual) on my car have bubbled out and warped for some reason. I have yet to take them off the car, but I'm wondering what might cause this. Is there foam underneath the mud guards that could have expanded/decayed and made them warp like this?
2) Unfortunately, My car was rear-ended while stopped at a stop sign. :icon_mad: Damage was relatively minor (visually) but it caused a large compression dent in the left rear quarter panel. I've been driving the car like this (until the head gasket blew recently), but I want to get it fixed. I just know that these things tend to be larger in terms of repair difficulty than what they look like on the surface. I have yet to get a quote to fix this (need to fix the BHG first before I can take it to the shop...but that will be soon), but what do you guys think? I'm just trying to see if someone's been through something similar...
Here's the rear 3/4 view...Note the dents in the rear quarter and on the rear bumper.
I'm generally terrible at body repair so I'll leave this to the pro's, but I'll probably do most of the dissassembly/reassembly myself to save on labor. I took off the bumper cover and some of the interior hatch panels and it looks like the dent is in an area that could be accessed from the inner fender well.
I'm just wondering if they'll need to put this on a chassis puller/frame straightener to be able to get that compression dent out.
The bumper reinforcement bar is dented and will need replaced along with the foam (I have a line on replacements already). Good thing is that tail lights/trim didn't get touched, and even the bumper cover might be able to be saved via heat gun reshaping.
Any ideas on how big of a job this is? If you've been through this before, how much did it cost you to have fixed?
Thanks!
-Mike
(BTW...Ignore the rear wheels in these pics. I've since obtained rears with the proper offset!)
Questions:
Thanks!
-Mike
