Alright now that it's been getting cold I figured I'd get my heat working that hasn't worked since I purchased the car. The heater core was bad in it so that needed replaced, I did that and had nothing on any speed.
I tested continuity of the resistor and it didn't show any so I replaced the resistor, after doing that i got the blower working but on low only and it barely blows.
I've tested the relay it's good applied direct power to the blower motor itself and it turns like it should on high, swapped in a known working climate control din from a buddies supra, checked all fuses I'm stuck I cannot figure out how to get my med and hi speeds. Also I know my vsv is bad but that wont effect motor speed and I have direct vac to the valve so I am getting heat just only on low. Any input would be great I'd love to get this working completely:1zhelp:.
The thing I've come down too is after looking at the hvac diagrams is that there is a blower control switch between the din control and the resistor, maybe that's bad but where is it located? Will I have to pull my dash again to find that?
