Block coming from Machine SHop... PICS
Supracentral
10
There's no way to perform proper machine work on an assembled long block.
Take it somewhere else, have it torn down and redone completely, by someone who understands what RA is...
I wouldn't trust anything done by a shop that described that deck as "really smooth"...
Supracentral
10
Nick M;1585578 said:
I don't think those ridges are ok for the head gasket. Stock yes, MHG no. That is from the cutting wheel being pulled across too fast, and is probably adjustable. Speed wise.
It's marginal. It might seal, it might not. Personally I wouldn't use any of it in its current condition...
Well, I'll ask this, can you catch your fingernail on the ridges? Seen ridges show up in photos and not be actual roughness on the surface.
Regardless, anything that shop did is in question now...
sylquebec
167
Quebec
WHat you see is what you feel. I can easily feel the ridges.
Is that the same thing about the head? Do i need to remove valves and etc to get it done? Thanks
supraguy@aol
Well-Known Member
Dec 30, 2005
4,240
Atlanta
I think at a minimum(if it's not done already- you need to remove the cams so that all valves seat.
As for the block- like poodles said, those coolant passages look terrible. I honestly don't even know if you can take enough material off to re-establish the normal boundaries of the passages. That's not the shop's fault, though, it's just from the corrosion. The shop should have inspected and advised you first, though. I say- grab another block. You can usually pick up a bare unit for $100-$200.
sylquebec
167
Quebec
...I'm angry right now, really angry. That was the second block i bring to them. THey tell me the first one was junk because it was crack on a bolt hole. So i bring them an other block i bought and they tell me it was in great shape. I will need to look how much materiel was removed. They write on the bill : 7.810 but i need to double check this.
Supracentral
10
Try to get your money back and under no circumstance let these people touch anything more complicated than a piece of 2x4 lumber in the future.
