bird cage is on
steveyblack
529
Nj
yah my light has been on since yesterday(just got the car running yesterday) and im wondering why its on...i have a steady temp, the coolant is prob old(flushing this weekend)...The overflow is above full(at the same level, just seems to have to much coolant)...could to much coolant cause the light to go on...there is no CEL,im stumped...both the coolant is free from oil, and vise versa...im stumped
thanks
steveyblack
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
This light only comes on when the overflow sensor thinks the coolant lvl in the overflow is low.
for whatever reason the sensor is thinking its low while its not. I'm no wiring expert but to me this would make me think the sensor is bad or something is on it causing it to do this or the wiring is shorting somewhere.
Unplug the sensor and see if the light goes off....that should eliminate the wiring.
steveyblack said:
yah my light has been on since yesterday(just got the car running yesterday) and im wondering why its on...i have a steady temp, the coolant is prob old(flushing this weekend)...The overflow is above full .(at the same level, just seems to have to much coolant).. could to much coolant cause the light to go on...there is no CEL,im stumped...both the coolant is free from oil, and vise versa...im stumped
thanks
steveyblack
steveyblack
529
Nj
IJ. said:
SB: Ummm how did you get that from a smilie?
I was just pointing out to Rump that you'd already said it was full.
lmao damn i suck at e-emotions/smiles...lmao
i thought you were pointing out the problem
ill flush the system anyways and see if its goes away
