OK, guys I have installed my rear Bilstein's, (fronts will be soon) with my stock shocks and I noticed that it actually raised my car quite a bit. I had blown shocks so this was to be expected. I have the c ring or clip on the middle ring, and there is still a 2" wheel gap. So if you are expecting a big drop from these, you will not get it, you will need lowering springs.
I called Bilstein and they said that it is a 10mm difference between the rings on the shock.
The fronts do not rub at all with the wheels and tires that I have.
Update!!
You can not run lower the car to the third perch setting in the rears!! This is because it will hit the tire if you have fat tires on the car. I have 17x10 5Zigen wheels with 275/40's and they hit if I put them on the lowest perch setting.
I just installed my fronts with the perch on the lowest setting with my stock springs and it looks good and drives great! So I have the rear shocks on the middle perch which is a small drop in the back and lowest setting in the front.
Wheels/Tires front: 5 Zigen FNOR1-C 17x8+35 245/45/17 tires,
Wheels/Tires Back: 5 Zigen FNOR1-C 17x10+35 275/40/17 Tires,
Wheels/Tires Back: Weld Prostars 15x8 5.5 BS MT 275/50/15 DR's
Here are some pics:
Update!!
Here are some pics:
