I just installed some new Bilstein shocks and Eibach springs on my 88 Supra and i'm a little dissappointed so far. First impressions are not that great. First of all my stock TEMs were so blown that I could compress them by hand with little effort and they wouldn't un-compress!
So I figured I would install some nice shocks and springs. Choose the Bilstein's because you can lower them a little more. But I think this is whats causing my front end to bounce a little when hitting a small bump. Like entering my garage. It feels like a pogo for a quick instance then stops. Doesn't seem to affect driving to much, but I can still feel it a little.
I'm thinking its because I have them on the lowest setting on the shocks and the fronts have no load on them at all. The spring is floating between the perch and the upper mount. I'm going to raise the setting to the middle and see if that helps.
Here are some before and after. I like the stance!
Before. 4x4 Supra!
After. Now I just need to get rid of the Sawblades!
Before. 4x4 Supra!
