bigger!
bowsercake
828
Irvine, Ca
Kind of off topic but, anyone running an upgraded CT with 550s, tuning(maft-pro, etc.), walbro pump, but no aftermarket fpr?
My reason is that the aeromotive FPR is really obvious and I would not like to pop my hood with one, they are way too obvious. Can a stock fpr in good condition do well enough with a good tune? Is there another toyota/lexus that uses a similar FPR to ours that can be used as an upgrade?
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Not recomended as you will most likely need to adjust the fuel pressure from it's base point with the larger injectors installed. You could put an Aeromotive in there and just have it hidden from plain sight, but easy to get to and adjust. You'll just need to have longer SS lines installed, if you're good, you can make those hard to notice too ;).
