I switched to ATE DOT4 fluid in an attempt to reduce stock brake fade(very high boiling point). Made NO difference. Needless to say, the stock brakes are junk for anything more than stock horsepower and "brisk" driving!
tekdeus;1290342 said:I switched to ATE DOT4 fluid in an attempt to reduce stock brake fade(very high boiling point). Made NO difference. Needless to say, the stock brakes are junk for anything more than stock horsepower and "brisk" driving!
Boiling point minimum: 536 degrees F5uprahboy;1290368 said:How high is the boiling point in that stuff? What pads are you running?
tekdeus;1290372 said:Boiling point minimum: 536 degrees F
Wet boiling point minimum: 388 degrees F
KVR semi metallic carbon fibre pads http://kvrperformance.com/shop/showcase.php
