BIG turbos make everything easier!
Apr 6, 2005
339
Alpharetta, GA
Eager to see the dyno sheets.
Would like to compare my dyno hp #'s against a another 7m with same turbo. :) I've seen MkIV sheets, and they aren't close to the curves I generated.
suprarick
68
Texas
I can't wait to hear all about it! What injectors are you running? And are you running a fuel pressure regulator and after market fuel lines?
MK3Brent
Very expensive....
Aug 1, 2005
2,878
Greensboro and Greenville NC
Hehe you guys are good.
Right now I'm having a tiny trouble with getting boost to come on sharply, but that's with the HKS EVC IV (Thanks Jake.) :rofl: I'm going to begin learning mode with it today and see if it helps, otherwise I'm going to get a different wastegate. (50mm is too big for the boost I'm trying to run.)
BOV is a tial.
As for fuel, I'm only using RC 550's, walbro, and aeromotive 13109... fuel pressure is whatever's good for me. (probably a little lower since it's going pig rich... I took off my AFC tune because I didn't know what to expect, but as to my predictions it goes mid to high 10's at WOT 3rd gear.)
I definitely wish the 7M revved higher though, this turbo comes on like a freight train.
Thanks for all the replies! :)
