BIC DDP - Worth getting the options with it?
InFrnt0fU
Lurking Supra Socialite
Any BIC DDP owners out there that could shed some light on whether getting the flex section and ceramic coating are worth it. Couldn't I just give it a couple coats of high temp paint and some heat wrap? Is the flex section really necessary for fitment issues? <---I care more about this than the latter question. I'm trying to get a downpipe and exhaust for under 1K but still have quality. Thx guys.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Flex section will definitely be good as it keeps the joints from cracking / breaking apart as it is not rigid. Also helps during installation.
Ceramic coating definitly is a plus to keep temperatures down, but if you can do that yourself, than its kool
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Nothing beats a ceramic coating, I wouldn't bother with that high-temp paint it will probably burn off, as far as the heat wrap, I've heard it can trap moisture in and cause your pipes to rust.
If you don't want it REALLY loud, get it re-routed
I got the DDP awhile ago, still haven't had the chance to installed it, and I already regret not getting it ceramic coated, and now that I've gotten a ride in a DDP'ed Supra, I probably should've gotten it rerouted ;) The wideband port is a good idea, but I don't like how close he mounts it to the turbine, not the recommended distance for a WBo2 sensor
As far as the flex section, i've heard from more than a few people who've been running a DDP for a couple years without one, and haven't had any problems.
Just my $0.02
Ckanderson
2,644
The beach
i would recomend.......
ceramic coating
no flex
not rerouted.
the DDP design is much better, and sounds awesome when it opens up! and it will be completly quiet when your not on boost.
shaeff
Kurt is FTMFW x2!!!!
11
Around
keep it vented. it sounds amazing. :)
i love my bic ddp.
2543arvin
Moving to Japan!!!
Nov 30, 2006
879
Jacksonville, NC
Nice thread, Im about to buy the ddp and test pipe with the thunder catback as soon as BIC gets back with me. Does anyone have a number for him?
goliath
Fears no evil!
Lancaster, PA.
Flex - yes
Ceramic - if you can aford it, why not.
Re-married - If you want all the performance with out the volume this is or you.
I have a BIC DDP-R and test pipe with a HKS Dragger cat back.
I love ever minute of it.:bigthumb:
shaeff
11
Around
^ that's what i'm going to be doing soon. (and an e-cut-out. )
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I picked up one of the first ones, before the re-routed option was available. I'm still not sorry. I recently gave it back to him to have the ceramic coating added, I should have just done that from the start.
Oh, and no flex section either, but I have solid motor mounts too, so it wouldn't help as much. I avoid speed bumps like a disease.
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
i like and dislike the exhaust leak sound (wastegate closed). i like how it reminds me enough of what open downpipe sounded like, it does sound pretty nasty just burpin the throttle. but, sometimes i'd just would rather have it quiet..
The exhaust leak (open wastegate) sound?
:bigthumb: :bigthumb: :boink: :bigthumb:
but it's kinda lame on stock boost cus i have the damn thing opening all the time.
mine is not ceramic coated, i shoulda gave it some spray paint to protect it, and its not flexy, i'd prefer flexy, i do bottom out a little. i'm not even that low.
5
flex section SAVES the exhaust manifold studs, it's worth it...
I dunno, I like both, wish I could get a cutout or something to flip between a full DDP and rerouting it...
