bic ddp question
Status
Not open for further replies.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
I was thinking it might just be from old age of the wastegate. If you go into depth and find anything keep us updated though, I'll do the same.
97TSiAWD
In need of more traction
Jul 18, 2006
124
Michigan
I have hit fuel cut at stock boost after installing the BIC DDP, test pipe, and Blitz cat-back. When it was warmer, it was fine and boost would usually creep from the stock 6psi to 8-9psi. However, once the cooler weather settled in, I hit fuel cut consistently in 2nd and 3rd gear as boost crept up to ~10psi. The exhaust flows well so the small wastegate hole probably just can't keep up.
It could be worse though. On my Talon, when I finally got the full exhaust installed, I would get boost creep from the low teens to ~20psi on a Big 16G turbo (Mitsu turbo). I finally got rid of that boost creep with a dump tube on the O2 housing.
Boost creep is often hard to avoid with internal wastegates and big exhausts, but the problem is more noticeable on the Supras since they run such a low amount of boost in stock form. My solution has been to upgrade the fuel system (pump, AFPR) so that I can lower the airflow signal (SAFC) and hopefully avoid fuel cut. I'm not done with the install yet so I can't say how successful it will be.
againstdawall06
298
mo
did you try to replace that vacum line? also, adjusting that little skrew on the side of the AFM does raise your full cut a pound or 2. iv had it done to mine and ran `12lbs on my old motor.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
Im also hitting fuel cut on stock boost on 3rd and 4th gears...it sucks. It will just start creeping to 11.5 .... hope becauseican can hear our crys for help lol.:biglaugh:
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
kinda what i was thinking... as i said... all i have is the dp, and a 3" straight thru muffler on the end of the dp.... doesn't even go past the door.... maybee i'll see if i can get the wastegate ported out, and put another wg actuator on while i'm at it
Insidious Surmiser
Formerly 89jdm7m
May 12, 2006
2,172
Oceanfront
i will be getting a wideband soon, so i may do this, but for now.... i have no tuning or monitoring devices, so i'll leave it as it is
havocatl
Boost get's you Laid
Apr 12, 2005
45
Atlanta, GA
I am having the exact same problem. I was running a BIC DP for a year boosting at 10-11psi. (Wastegate shimmed). Last week i installed my new DDP and it creeps up to 14-15 psi!!! Usually only in 3rd and 4th gear. I hit fuel cut around 14psi.
I did a search on Supra Forums and I read something about porting the Wastegate hole.
Does anyone else know how we can fix this? I hate hitting FC... its pissing me off lol.
I don't have any boost leaks. This problem started as soon as i swapped the normal DP for the DDP.
mkiiSupraMan18
Needs a new username...
United States
I got the same probs w/ my 3" turbo elbow...I'm hitting FCO at 10psi also. But I know for a fact the waste gate flapper is not hitting anything and can open up completely.
I just figured it was my AFM?
*edit*
Maybe I'll swap the stocker on and see how things go after that.
97TSiAWD
Jul 18, 2006
124
Michigan
There are a couple of things that can be done to prevent boost creep: you can get a larger wastegate flapper and bore out the wastegate hole or just go to an external wastegate. Personally, if the creep is limited to a max of around 10-11psi without hitting fuel cut (as I mentioned, I'm not done with the fuel mods yet), I will just live with it and make sure I have enough fuel to support that amount of boost.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
That's why I like my Cooleze megamouth DP ;). I think I may have got boost creep once or twice, the stock gauge jumped up past the 8 mark and then went back down to normal, but I think it's just the gauge being a POS.
havocatl
Apr 12, 2005
45
Atlanta, GA
I'm going with an upgraded CT-26 early next year so i guess i'll just live with it for now. I assume that the shop that will upgrade my turbo will be able to port the WG...
Status
