anyone has one of these things installed...notice and increase in power ? whats your thoughts about this ddp...is it worth over 400 bucks?
boosting185 said:thank you mass.
boosting185 said:anyone has one of these things installed...notice and increase in power ? whats your thoughts about this ddp...is it worth over 400 bucks?
vdragonmpc said:I will say that the extra cost of the coating isnt seeming to be worth it. Mine changed color a little over a month after running it (rain spots it looks like) then when under the car I notice that its rusting. It will look HOT when you first get it but the coating will apparently go away shortly.
Also get the 2nd bung I wish I had as I would like a wide band now. I like that it made more room and made removing the turbo easier.
V
pb92supraturbo said:Are you referring to the ceramic coating? I've had a ceramic coated BIC DDP on my car for over a year and it still looks great. No rust at all and none of the coating has come off. The coating will dull slightly at the elbow when it goes through some heat cycles but its still 100% coated.
