BHG pitting in block in under 20 days?
s.u.p.r.a
52
Roswell, GA
Hey all,
How likely is it that a ~2-3mm groove was made in the block by a bhg in under 20 days?
It's a 2 inch semicircle around the left side of cylinder 6 about a centimeter away from the cylinder. It was caused by the gasket pushing out.
I ask because I need to know whether I was shipped an internally damaged engine (in which case AMEX is going to work on getting a refund)
PS: NEVER buy from japanracingengines.com -- the engine was shipped on its side and I've had problems ever since.
s.u.p.r.a
52
Roswell, GA
The pitting is in the first pic.
Is the corrosion around the coolant passages an indicator that I probably need the block machined?
If so, anyone wanna buy a car? :nono:
Zach
ECUMaster USA
Apr 6, 2005
375
TX
There's no way that was done in 20 days, especially if you were using the proper antifreeze/water mixture. That block has been jacked up for a lot longer than 20 days I guarantee you.
super.secret.supra.club
1,304
San Diego, CA
+1 on the machining.
It's nowhere near how bad the corrosion was on my 7m when I first got my hands on it. The areas where it's rusting in your picture were just plain gone on my block. Cost me quite a bit to get that fixed too.. :3d_frown:
