The air could have came from not filling the coolant propperly and I have had the same problem. But your'e right. I may be wrong. If I am ......, don't tell my old lady.
supramacist said:I agree with fig. But the down fall to doing it your self is finding the time and actually sticking with it. If it was my dd I would tow it and have toyota do it. Especially if money was no option.
supramacist said:Dude, you want to get like a 160 degree t-stat.
A fan shroud is right at 125$ a toyota only part. I ran my na with no shroud for a day or so while working on it and I had the exact same symptoms. The car can't cool it self propperly without one. Mine was busted all to hell. When I bought it. Wired up on one side. I rigged it to last as long as I could but buying a new one is inevitable.
KILLERMK3 said:What i was askin was, how can i have coolant in the tb w/o entering the afm or ducting?
starscream5000 said:A stock Supra t-stat is suppost to be 190 degrees. If you're getting a new one when you do the new hg (might as well, just to be safe ) don't get anything lower than 180 degrees. The engine does need to be warm enough to run properly.
