Today i pulled my 87 out of storage and it overheated quickly after getting on the road. The temp gauge stayed at mid-way, then i tapped on the gauge cluster to free up the sticky fuel gauge i have and the temp gauge shot up. I shut off the car and jacked up the car to raise the front car so i could burp the cooling system. I restarted the car with the radiator cap off to see no coolant, i refilled the radiator and burped it for an hour plus. All seemed great as i went to take another test drive, so i thought. As i drove easy, the gauge rose to 3/4 and fell back to normal, this did this repeatedly. Then i noticed the belt making noise. oh no...i pull back over to see the coolant resivior overflowing onto the fan(no fan shroud) and getting sprayed onto the motor. As i make my way quickly back to my house, the car starts to run really ruff. It sounds like its running on 4 or 5 cyl. I made it home without overheating again. Wooh. My dad suspects the thermostat, i think BHG.:3d_frown: If your still reading this thank you. I need help to fix this quickly because my dd is dying on me a lot. Those s10's aren't the most reliable.:cry: Sorry for such long post. Thanx Shelby
