jdub;1290003 said:Like a fuse, but you can reset it. Think power distribution panel on a house.
viper92086;1290007 said:^if you read the orig post IJ it's already setup liek that
jdub;1289786 said:You would have to tap the round flat spot on the side of the water neck above the ECU coolant sensor. There is no flow through the rad when the T-stat is closed...you could remove the jiggle valve at the top of the T-stat, leaving a small hole for constant flow. This is a good mod to do regardless to prevent a pressure build-up behind the stat.
The aux fans come on at 107 deg C iirc.
tissimo;1290017 said:Do the fans really need to be on if theres no flow to the radiator?
jdub;1290023 said:They need to come on just prior to when the T-stat opens. Hence the suggestion for an 75-80 deg C switch in the water neck before the T-stat.
The factory aux fans are there to assist when the A/C is running and the thermal load to the radiator increases.
Viper - If you go the CB route, I would want one that is a manual reset. I'd like to know if/when it pops.
