been parked for a few days, cause i wasn't starting this with the engine warm at all, i'll for certain want to replace the elbow and downpipe at a later time, but i can't afford it at the moment. I have a swivel ratchet, so that's not an issue, but it looks to me like one of the 3 is gotta be a pita no matter what tools i have. i like the idea of unbolding the exhaust completely and sliding it back out of the way. but i'm toying with the idea of lifting it all (manifolds still attatched) out with my electric hoist, hopefully reducing the chance i might strip out a stud on the exhuast which i can't afford to have repaired atm. Right now the pulleys are off, timing belt is removed, cam gears and rear plate are off, valve covers and valley cover are out, upper intake manifold and all related electronics are out of the way. Also all coolant lines on the motor and the oil lines on the turbo are off. the only things holding the head in are 14 bolts and the exhaust.
is there any reason why i can't leave the manifolds on when i pull it? with the turbo and upper intake removed i don't see any issues with too much weight or anything of the sort, then i can carefully remove the exhaust and intake manifolds with it on the bench instead of in the car
EDIT the nuts are now sprayed down, hopefully i can break them loose when i can get back to the car on Wednesday, anyone know what size the turbo to elbow bolts are? I'm missing one.
