Best valve cover gasket ?
Wills7MGTE
( . )( . )'s RULE!!!!
May 12, 2006
1,077
Jackson, MO
Well you gotta be careful when you install them its easy to make them leak, I replaced mine about a year and half ago with Felpro gaskets and also replaced the bolts that came with gasket kit, I can't remember how much they cost I got them through napa here in town, they still sealed up nice no leaks.
I also beadblasted and painted my valve covers with some high heat paint, painted em a toyota red they turned out pretty good still nice and clean I figured theyd turn to crap but they havent.
So I guess I'd get a set of FelPro's and see how they work for you, they work fine for me, but I had a buddy help me install them and we were careful, you can screw them up very easily.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Any should work as long as you put them on right: put the sealant where the TSRM calls for (not too much not too little), and torque them down properly! DO NOT ratchet them down with a wrench and hope its right, use a real inch pound torque wrench and tighten it down properly and you wont have problems.
j3pz
still learning
i like to get some RTV that will work with petroleum products and put a little on my fingers. i then apply a light film on the gaskets to make them tacky. dont let it build up anywhere, smooth it all. i have not had leak yet. and like the others above have said, use the tq spec on the tsrm.
i also have felpro gaskets.
shaeff
Kurt is FTMFW x2!!!!
10
Around
xms;1236228 said:
Who makes good one, mine is leaking and there brand new :cry:
Done.
arizzle
Lov'in the boost.
Nov 1, 2006
996
burnaby, BC
im using FELPRO, there great not leaking but i also changed the screws into bolts and i torqued them to spec. maybe yours is leaking cause its not installed properly.
92nsx
2,957
Clearwater, MN
Toyota gaskets FTW. I have removed my cam covers (with same gaskets) 3 times now since the rebuild and still no leak ;)
