If you saw my other thread about my gauge reading high, you'll know that I need to use the sensor that came with my gauge. With that being said, where is the best place to put the sensor on the 1jz? I appreciate you taking the time to read this.
TaSe said:i usually see them on the top rad hose. then run the wires to the gauge....
one of these
sensor inside of it, cut the hose to fit this on both sides and thats about it.
IJ. said:In an air conditioned garage with a big screen TV in the background?
IJ. said:The motor of course it'd be silly to install it on the bumper![]()
AF1JZ said:Your killing me Ian.
Alright, where on the 1jz engine would I install a water temp sensor if my car were in an air conditioned garage with a big screen tv in the background?
IJ. said:I'd go for somewhere in the cooling system if it were me
(Toyota took a guess)
I know someone here that has it in there upper rad pipe for there 1J seems to be a good spot
IJ. said:Having said that put it in the stock hole if you can it's the best spot to get a quick consistant reading.
IJ. said:LOL I was talking about the Sender![]()
