Alright. I have 4 gauges to install and I want to make sure I am placing them in the correct place.
Well here is what I have:
Water temp
Oil Temp
Fuel pressure
Boost
Water temp should I put that in place of the BVSV? I have a fuel cell and no longer will use the BVSV anymore, plus it broke.. the two nipples.. whoops :biglaugh: Now would that be a good location?
Oil temp Gauge would I want that in the oil pan at the bottom near the bottom..*
Fuel pressure I would like to tap in a hole for it, many people.. use the Cold Start Injector hole, I could do that but I like nice start ups
Boost, yeah I can tap that into the intake manifold, or a vacuum line.
Anyhow if I have anything wrong here or you have a better idea let me know I am open to anything, I just want the most accurate readings, thank you.
Water temp
Oil Temp
Fuel pressure
Boost
