all mk3's come with the same fuel pump. 7mge, 7mgt, 1jz, 1ggt... the stock pump will outflow stock turbos, so you're good there. check other components if you have a rough idle.viperkillertt said:I dont have any super high power goals. My most immediate goal is smoothing out my idle and having sufficient fuel at full boost so i dont damage my engine. How much are the stock TT pumps appx? I have seen the bosch going for about 200 dollars or less.
