Best crossmember for swap
Cya
628
Columbia, S.C>
Ive come to a cross road, the mounts with the car are shot and Ive decided to got BiC brackets and poly mounts. I have two crossmembers 89+ and pre-89, which crossmember makes life a little bit easier as faar as manitenance? I noticed the pre 89 sits the engine higher and the 89+ is a little lower and back. Any input?
eman2289
Noob..but not incompetent
Feb 23, 2007
618
Jersey
I have never heard of either needing maintenance. If I were you, I would just put the newer one in.
Cya
628
Columbia, S.C>
Let me rephrase, which mounts would be better for general mantenance purposes? Such as oil changes, which mounts tend to hold up better,...things such as that.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
pre 89 mounts are solid. 89+ mounts are liquid filled (tend to die faster) as for which cross member to use......
the BIC mounts come in a pre89 form and an 89+ form. which did you order???? then you'll know which xmember to use.
Cya
628
Columbia, S.C>
I was thinking of going with the 98tt motor mounts if I stick with the 89+, if I go pre-89 is was going to get the poly mots from bic. Im trying not to go solid as long as possible, from what Im reading they arent what you want for a DD.
The Reaper
Jan 10, 2006
1,909
Florida
i would go BIC and pre 89 Xmember. i mean you already bought the brackets and mounts why not use them????
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
BIC said himself he prefers pre 89 square mounts. i would want poly round mounts with my 89+ the solids are a pretty harsh ride but it really isnt as solids in a civic or something
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
I have the pre 89 cross member with the bic mounts and I prefer it over examining the 89+ mounts.. As others have said, if you're not one way or the other and you have the means, then why not.
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
The best motor mounts and crossmember is the 86.5-89.5 they are solid and way stronger, cheaper they dampen motor vibrations less but you have less flex & play in your engine bay.
most people running more then 500hp will tell you to use the solids the liquid ones tear up easy and cost about 90$ each from toyota.
if you dont believe me hook an engine hoist up to the engine of your car alone lift your whole car by the engine and jump up and down on the front of your car the liquid ones will go probley with out even jumping on your car the solid one will out hold.
