Best boost controller?
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
MassSupra89 said:
Yes you go with a GM 3" MAF. or you can go MAFless, I'm still doing my research myself and this is most likely what I will go with soon.
you can't go MAFless... but you can put the MAF in your IC lines and then just do an intake to the turbo...
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
bigaaron said:
With maft pro you can!
I thought you still had to have the GM MAF... I haven't done much research on maftpro... I thought you were refering to maft...
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Nope, with the pro model you can put in a MAP sensor instead, that can go right in the manifold.
PS: Now you know why searching for 20 minutes didn't turn up any definitive answers - nobody can agree on this topic!
diy guy
86
dallas
KINGPIN33 said:
What would be a good suitable one for a low budget setup? I just want one to control from inside the car and will only be running stock CT26 and maybe 10-12 psi max.
Bascially what's best bang for the buck for a low budget BPU supra?
heres a little diy one i made,
it switches from two boost settings with a switch mounted on your dash and costs about $50 to make, the most expensive part is the solenoid so if you can salvage one from a junked car (just your basic 12v open/close solenoid) it'll be even cheaper
as far as ebc's, i like turbosmart's e-boost
http://www.turbosmart.com.au/boost_control_electronic.htm
SupraSized
12
Whizzzconsin
HKS EVC 5 I love this controller. When you go from a home made manual boost controller made from parts at Fleet Farm cut and brazed to this... you feel a bit spoiled.
MKIIINA
Destroyer of Turbos
Plano, TX
HKS EVC 1- old school! easy to set up install and minus hitting it with a hammer cant break it. the avcr and e01 etc can be a bitch to set up correctly and if you do something wrong it can bitch to you. fuzzy logic sobs ;)
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
I'm 100% satisfied with my blitz SBC-ID, it has great warning features, its easy to use, great boost display (peak and hold gauge in PSI). I actually installed it in front of the stock boost gauge and it looks awesome there. I'd definately recomend it. I got a great deal on it too, for 300 shipped.. usually you'd be lucky to get it for 400 shipped.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
I had the greddy ones and this time I was enquiring about the AVCR and heard mixed reviews, specially about the setup.
I went ahead and bought the AVCR , and I think It was one of the best decision concerning boost controllers.
Its simple to hookup and seting up a breeze, not as hard as most had made it sound to be.
Holds boost real good and displays a bit more than just boost and vacuum.
I like the AVCR a lot ...
