Best boost controller?
I searched for twenty minutes for an opinion on the best boost controller before I started this thread. I have an HKS manual boost controller. I'm wanting to go to a digital one. What have some of you guys used and had good luck with? They all seem to be around 350 to 600 dollars. Do they serve any other purpose? Any help would be appreciated. I want to order one pretty quick. Thanks alot.
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
aye mate said:
Apex-i Avcr.
Anyone disagree?
thats what I'm using....
GrimJack said:
Lol... my favorite is still the Greddy E-01. Hows that for covering all the bases?
Or maybe the MAFT pro.
If I knew about this earlier this is what I'd have though... definatly look into maft pro...
KINGPIN33
183
Canada
What would be a good suitable one for a low budget setup? I just want one to control from inside the car and will only be running stock CT26 and maybe 10-12 psi max.
Bascially what's best bang for the buck for a low budget BPU supra?
jmcboost
Missouri
I would say try the profec-b or something newer. They are a littlie hard to tweek, but the aren't that expensive used.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
bigal0043 said:
just get a manual boost controller for like 20 bucks and just get it dialed in to 10psi and call it a day
Agreed. Dr. Jonez sells a fantastic one that works great, it's under $30 if I recall.
If you *must* have an EBC, the profec is the cheapest and works fine for what you are describing.
Mr.SelfDestruct
I build planes... yeah...
May 27, 2005
608
everett, WA
arz
Arizona Performance
Nov 14, 2005
955
Mesa, AZ
www.ArizonaPerformance.com
Any 10-30 psi pressure regulator would work great
Why can you control the max boost per gear. I know the AVCR will do that, just havent plunked down the cash yet. I have Traction issues in first and second and was hoping ot control it with that if needed. YES I already have my eye on tires. But the DR's Im running now are holdin up for now.
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
read up on maft pro... it's awesome... yeah I havent gotten the chance to play with my avcr as it isn't installed yet... but it will be in less than a week... :biglaugh: that means no traction through 3rd I'm guessin...:evil2:
Joel W.
Just A Jedi
Nov 7, 2005
1,561
Washington
arz said:
Any 10-30 psi pressure regulator would work great.
I use an air regulator in cab for boost adjustment, but it also requires a dual port actuator to work properly? Or did you mean a bleeder valve? Just wondering.. :)
If I go with the maft-pro, do I do away with my lexus afm? I just did the fuel pump swap to a walbro 255 and bigger injectors. I guess 400 for the maftpro is better than 400 for a good boost controller.
MassSupra89
Almost done.
Nov 3, 2005
1,707
MA
Yes you go with a GM 3" MAF. or you can go MAFless, I'm still doing my research myself and this is most likely what I will go with soon.
I'm glad I could help Aaron. By help, I mean buying an intercooler from you. I've got mine installed, but I haven't got my pipes right yet. I hope to get it finished tomorrow. Make sure you post about the maft pro when you get it installed. I'm very interested in getting one. thanks.
