bellhousing confusion
Feb 28, 2008
192
North Babylon, New York
ok so i have been tryin to get my hand on a r154 transsmission for about a month now to put on my 1j swap i have a w58 and a friend told me that i can use that yes i kno its a weaker tranny but i'm having it upgraded a little now the main question is the bellhousing for a r154 that i see all over the internet will that bolt up to the w58
Feb 28, 2008
192
ok so i need a bell housing from a 2jzge motor now as far as a clutch and pp i would need it from the same 2jzge right? and what flywheel would be needed to make that work on my 1jz
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
you need a 2jzge manual flywheel and any w58 clutch setup (the 70$ ebay special should be good enough) and the bellhousing will be a 2jzge bellhousing thats for a manual transmission and after you get a driveshaft (you get this from a non turbo manual mkiii supra) vuala! a drivetrain.
