So starting getting rod knock in my supra, was only knocking on start-up until it received full oil pressure, then knock went away. Pulled motor anyway
Attached are the pictures of the big end and mains bearings. These big end bearings were put into my car 4-years ago and done around 20 days at the track and 5000ish kms of city driving. They wernt clearanced (yes i know, i was in a rush and didn't have plastiguage). The main bearings are toyota original. At the same time of fitting the new big ends i shimmed the oil pump, With a typical toyota nut which is approximately 5.5mm thick. I hear people say between 5-7mm shim so figured sweet that will do
A diesel mechanic friend of mine inspected the bearings and he thought that the pitting and the hole in the bearing caps was caused buy excessive oil pressure, damaging the bearing surface over time and eventually digging a hole in the bearing
No 5 is the worst shell with the biggest hole, the cap side is the left side, the other image is no 2 cap side on left side also
Or could it be a clearance issue? Hence why im asking the knowledgeable community of supramania
The catch is that i dont have a oil pressure guage on the car, only the crappy standard one. so its impossible to know what it ran pressure wise
Now for reference the car has a full oil filter relocation setup with a oil thermostat and a big oil cooler, turbonetics turbo, manifold upgrades. 12psi. stock ecu
Thanks very much
Nick
Thanks very much
Nick
