jdub;931165 said:
Here's the spring seat pressures for the various ones available:
Stock - 35 lbs
Comp Cams - 55 lbs
BC - 60 lbs
Ferrea - 67 lbs (dual spring)
Becomes a factor with more agressive cams and/or higher rpm (8K +) levels. The Comp springs are the best bang for the buck if you're running stock engine rpm IMO. And you can use the stock retainer, no problem.
Couple days ago
This is based on the chart at compettion cams; However Suprarich did a report back in the BC cam group buy thread where he addressed that while at the stock seated height the Competition cams have a greater seated pressure, which I recall was about equal to the BC springs, or higher. You may want to check with Rich on his findings, and Data that those springs to be much higher than the stated pressure on that chart for our heads. Again this was because of the seated spring height for our cars was different than seated pressure listed on the chart from what I recall. Rich you want to chime in here and correct me f I have mistated your data?:naughty::biglaugh:
The revvng over the stock rpm limit to 8000+rpms I definitely agree with JDub that we should use ferrea's, and according to Chevyeater, and I.J. that's the only choice for them. So your summary is quite accurate Jdub; However I felt the need to add my findings from personal use, and also to help along the factual data findings with a valve spring that is a viable option. "I heard these springs seated pressure are higher than the seated pressure of stock 2jzgte motors", and the 2jz owners have revved their stock motors to 7200+ sucessfully.
