high psi 1jz said:Those mud tires need to go low pro fo SHO!
It would look even worse with low profiles on a small rim, not to mention the over all diameter would then be way off. The only reason for running a lower profile tire is when running a larger OD wheel, this keeps the OD of the tire the same as stock.
EDIT:
